Allows GRE tunnels to be disabled.
tunnel_name | GRE tunnel name. |
Enabled.
Use this command to disable GRE tunnels.
This exanple disables the tunnel named "myGREtunnel":
disable myGREtunnel
This command was first available in ExtremeXOS 15.3.
